Rear Disc Brake Swap
Old Sep 7, 2012 | 11:36 AM
JGC403's Avatar
JGC403
Originally Posted by 4990Ram
Another option is to get a rear end out of an '02 or new 1500.
I picked one up here locally for $300.
Those use the metric bolt pattern though.
Old Sep 7, 2012 | 11:41 AM
JGC403's Avatar
JGC403
Mopar Muscle mag installed a set of disc brakes on the back of a Dart. They did a before and after test and the disc brakes stopped 11 feet shorter.
Yes the ZJ brakes have a drum parking break inside the rotor.
Considering most of the parts can be obtained from the junkyard its not an expensive upgrade.
http://www.moparmusclemagazine.com/t.../photo_12.html
Old Sep 7, 2012 | 03:03 PM
SEAL's Avatar
SEAL
I look forward to hearing what specific parts you use and seeing a running tab on the project. Good luck.
Old Sep 7, 2012 | 09:54 PM
grimm's Avatar
grimm
On the issue of converting 5 0n 5.5 to 5 on 4.5 wheels, it was done on my '85 Ram. The guy just swapped the front rotors and on the back he swapped the whole axle, but I would think you could just swap the axleshafts, no?
Old Sep 9, 2012 | 01:38 AM
4990Ram's Avatar
4990Ram
5.5"=139.7mm, same thing.
Old Sep 9, 2012 | 11:26 PM
JGC403's Avatar
JGC403
I read some where that some people were having problems using the metric wheels on the 5 on 5.5" lugs.
