Buzzer under dash
Buzzer under dash
I know this is most annoying to most folks but its a help to me, i need a new buzzer for when the key is in the ignition and or when the lights are left on , anyone know where I can get one. I usually remember to turn them off but its usally after I have visually looked at the lights to make sure they are off and then go back and push the switch in. Thanks Birge
Birge, NAPA sells an aftermarket kit as does a place called www.liteminder.com. It is a pezo buzzer that has two wires that connect to your fuzes. The fuse connection/splicers are tough to work with and the pezo buzzer is a bit of a piece of junk too; I would suggest getting an ATP Fuse Block Add-A-Circuit from any auto store or:
and a 12 volt pezo buzzer from Radio shack.
Instructions:
1. Switch off all your electrical items and ignition.
2. Connect one ATP Fuse Block Add-A-Circuit to the Instrument Panel Lamps fuse.
3. Connect the red wire from the pezo buzzer to this.
4. Switch headlights on and touch the other wire from the pezo buzzer any other fuse until the buzzer sounds. Connect this wire to that fuse with the second ATP Fuse Block Add-A-Circuit.
5. Mount the buzzer somewhere out of the way.
6. Test: Buzzer will only sound if lights are on and ignition is off. Turning ignition key on will silence the buzzer.
Instructions:
