Eliminate Rear Drum
So you plan on swapping the engine in this truck, and the transmission, but you won't fix the brakes?
What on earth is your logic behind this? If the truck isn't worth fixing the brakes, why would you swap the whole driveline?
Do you understand how backwards this could sound?
A mechanic I knew once asked me what the 3 most important parts of a vehicle were, I of course said....The amount of power the engine makes, what kind of shift kit is in the automatic transmission.....and the gear ratio in the rear end...
He informed me that in reality it's the tires, the brakes and the steering/front suspension stuff, and as unglamourous as all that is it is actually the right answer.
I once had a truck where the rear brakes didn't work.....I only found out because one of the front brake hoses broke as i was coming up to a red light, it was very lucky I didn't hit anything. Trust me just fix the brakes
You can get a pair of decent drums at the junkyard for $20 bucks, a set of shoes at orielly or auto zone is another $20 bucks, not stopping in time can kill someone, possibly yourself, possibly your nieghbors child.
Man up to the $40 bucks and half a day it takes to FIX YOUR BRAKES!
Rear brakes are so cheap its stupid to not fix them.
Also I am curious, when you jacked up the truck, started the engine, and put the truck in gear, did you chain it to the garage in case it came off the jacks? Cause that way if it came off the jacks because it was running and in gear it would pull down the garage and you could buy a bicycle with NO BRAKES with the insurance money!
