deciding on a cam
Old Oct 27, 2012 | 12:34 PM
  #41
naturedude32's Avatar
naturedude32
i gotta stop trusting people to help me get projects done, my truck is at my buddies house a couple miles away from my apartment and he keeps flaking out on me. i've been without a vehicle for a week now and i'm sure if i woulda done it at a different friends house that i know for a fact is reliable it would have been done 5 days ago...
Old Oct 29, 2012 | 09:31 PM
  #42
naturedude32
its all in and it turns over, sounds like it wants to start but back fires through the intake every once in a while.
Old Oct 30, 2012 | 08:31 AM
  #43
wontacceptthis's Avatar
wontacceptthis
Timing off?
Old Oct 30, 2012 | 07:56 PM
  #44
naturedude32
thats what its lookin like, unfortunately my timing light isnt so accurate anymore for some reason. not it'll start and run fine till i put it in gear and then it'll stall. it heated up pretty fast too, seemed a little too fast
Old Oct 30, 2012 | 08:48 PM
  #45
SixGun's Avatar
SixGun
It may not be your timing light. Did you unplug the water temp sensor? After warmup, unplug the temp sender and recheck the timing. Are you using 10* BTDC? I'm assuming that your settings would be like a 91.
Also, don't play with the idle screw. There's a process to that as well.
Old Oct 31, 2012 | 08:37 PM
  #46
naturedude32
we turned the distributor as much as possible, its only able to turn a few degrees either way. and i plugged the wires in to the distributor according to the firing order/hayes manual. did put the rotor where it was supposed to be, agreeing with the timing mark on the crank pulley, i'm honestly running out of patience and time. i have to have this done by friday morning to work in brighton michigan for the weekend, and i live in lima ohio btw. i'll try unplugging the engine temp sensor tonight after class
Old Oct 31, 2012 | 09:00 PM
  #47
crazzywolfie's Avatar
crazzywolfie
is there air or fuel being blown out the throttle body when you try cranking it? it could be so easy to get the distributor shaft in 180* off.
Old Oct 31, 2012 | 11:03 PM
  #48
naturedude32
yeah, i tried tellin my buddy its 180 but he doesnt wanna listen. i'm turnin it around when i get to his house. i cant begin to express how much i appreciate your help, never once did anyone help me on the bmw forums when i had a bimmer
Old Oct 31, 2012 | 11:12 PM
  #49
crazzywolfie
i am guessing most of those people with the bmw's must pay someone else to fix there vehicles for them.
for the little amount of time it takes to take that distributor out and rotate the distributor shaft i would at least try it. the worst thing that happens is the truck won't start.
Old Nov 1, 2012 | 12:33 PM
  #50
naturedude32
appaerntly they did, no one knew how to rebuild a diff, do a five speed swap or re-write the ecu on a 90's 3 series...i figured it out though haha, i'm not just some jackass. i kinda know what im doin but i havent ever dealt with a distributor, i did turn it 180 and it didnt do anything. it refuses to start with the other disributor but will start up and run with the old one
