Problem With Hydraulic Slave Cylinder
Old Oct 20, 2012 | 05:07 PM
Augie Dog's Avatar
Augie Dog
Default Problem With Hydraulic Slave Cylinder
Hey guys,I am new to this first gen site. I usually visit the Durango site. Anyway I am looking for some advice. I have an 86 D-100 RWD with slant six and A833 trans. This is a project truck and I basically replaced the blown engine with another Slant 6 and went through the trans. I installed new clutch and pressure plate. After getting it all put back together I drove it home and it shifted fine. Fast forward a couple of weeks I went to drive it and it would not go into gear. The trans just grinds. The clutch slave cylinder was suspect so I just installed a new slave bled the system and it is still doing the same thing. What are your thoughts? Maybe I didn't bleed it enough. I am not familiar with the hydraulic assist system so this is new to me. I don't know what the pedal is supposed to feel like when bled and operating properly. Thanks for your advice.
Augie Dog
Old Oct 21, 2012 | 07:40 AM
SEAL's Avatar
SEAL
Have someone push the clutch pedal while you watch the cylinder and fork. How far does the fork move? Does it grind in all gears or just first? I doubt it is a bleeding problem or the problem would have been there from the start and not developed later.
Old Oct 21, 2012 | 09:53 AM
Augie Dog's Avatar
Augie Dog
Thanks Seal.it grinds when I try to put it in reverse and any other gear it doesn't do anything, The shifter acts like it is jammed up and can not engage.
Old Oct 21, 2012 | 10:04 AM
SEAL's Avatar
SEAL
Can you get it in all the gears when it is not running?
Old Oct 21, 2012 | 07:10 PM
xjarhead69's Avatar
xjarhead69
Could the shifter linkage be out of adjustment?
Dave
