1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have a 90 D250 4x4 with the factory 4 speed tranny. The truck is geared low I would estimate it to be at least a 4.10 or higher. My question is this; can you put a 5 speed from a second gen in these trucks with little to no modifications? I am just looking for that OD gear for the highway lol, 55-60 is all she wants anything over that and I have to stay pretty deep in the pedal.
I would rather go with the 4500 because its good up to 18000lbs where as the 3500 is only good up to 11000 but that will he plenty on this truck just gonna pull a tractor and horse trailer.
From what Ive read they are pretty much a bolt in swap if you have an auot OD. Im in the middle of the same thing but going from a auto to an nv3500 in a 79 power wagon. Im trying to find out if the slave cylinder from the 99 will work with the 95 nv3500 trans so I can use the bolt in style master cylinder from the 99.Im also trying to figure out if my 205 passenger drop tcase will work on the 5 speed.It came off an auto OD. Everything Ive read says the tcases from the autos bolt right up to the 3500 5Speed but no one has mentioned a 205. All the threads Ive read are all using 231 and 241 tcases.
