High Idle
Old Nov 7, 2012 | 11:25 AM
SEAL's Avatar
SEAL
Just for information. The double throttle return spring is the way it is supposed to be. It is insurance that if one spring fails the throttle will still close automatically.
Old Nov 11, 2012 | 09:16 PM
ghonhee's Avatar
ghonhee
Hmm interesting. Thanks for the info SEAL. Is the IAC you're talking about this http://www.napaonline.com/Catalog/Ca...91_0336303439?
As I was checking around the engine today, I found a threaded hole on the intake manifold with nothing going into it. I need to check more into it. It is behind the alternator.
Old Nov 12, 2012 | 06:13 AM
SEAL's Avatar
SEAL
I can't open your link so I can't answer your question.
Old Nov 12, 2012 | 12:39 PM
ghonhee's Avatar
ghonhee
Sorry about that. This should work: Link
Old Nov 12, 2012 | 01:27 PM
318power83's Avatar
318power83
That looks right, i put one on my 89 I switched it with one off a 91 ramcharger, when I switched mine it made a difference in performance and mileage
Old Nov 12, 2012 | 02:03 PM
SEAL's Avatar
SEAL
I agree that is the correct part. It has different names. ( IAC Idle Air Control Motor, AIS Automatic Idle Speed Motor, ISC Idle Speed Control Motor)
Old Nov 12, 2012 | 09:02 PM
ghonhee's Avatar
ghonhee
Alright. Thank you. I'll let y'all know what happens
Old Nov 19, 2012 | 11:47 PM
ghonhee's Avatar
ghonhee
It seems like the ISC motor was the problem. Switched that out today and the high idle symptom is completely gone. The intermittent check engine light is still there but all traces of the idle problem are gone. Thanks for the help guys.
