1990 ram alternator problem
Old Nov 13, 2012 | 12:23 PM
PEEKIN's Avatar
PEEKIN
Default 1990 ram alternator problem
i just bought a 1990 ram 4x4 318 tb inj. it has a band new alternator on it but still does not charge? any other things i could check or would the new alternator be faulty
Old Nov 13, 2012 | 12:52 PM
crazzywolfie's Avatar
crazzywolfie
i would probably blame the computer before i would blame the alternator on these trucks. have you checked to see what the voltage is on the large lug at the alternator?
Old Nov 13, 2012 | 02:28 PM
SEAL's Avatar
SEAL
I would check the grounds. Grounds are known problems in our trucks and the alternator won't work if it is not grounded properly.
Old Nov 13, 2012 | 07:30 PM
PEEKIN's Avatar
PEEKIN
cool will check both of those tomorrow
Old Nov 14, 2012 | 06:44 PM
PEEKIN's Avatar
PEEKIN
problem solved it was the ecu. charging great now but i have another issue lol i'll make a new post for it later
Old Nov 15, 2012 | 05:12 PM
Sniper X's Avatar
Sniper X
What did you do to the ECU? Just reset it?
Old Nov 17, 2012 | 10:59 PM
PEEKIN's Avatar
PEEKIN
the voltage regulator is built in the ecu ,
Old Nov 18, 2012 | 07:51 AM
SEAL's Avatar
SEAL
I think what Sniper X is asking is did you just reset the ECU or did you replace it?
Old Nov 19, 2012 | 06:24 PM
PEEKIN's Avatar
PEEKIN
replaced it ,reset would do no good if regulator is toast
Old Nov 20, 2012 | 01:08 PM
Sniper X's Avatar
Sniper X
Yeah, I meant did he reset the CPU before starting the truck with the new alternator in it. PLUS, I am wondering if he is getting no charge out of it as in what is he measuring the amount of charge with...and where? The way to do it is with a VOM on the battery for a pretty accurate reading, but at the gauge.
