violent vibration
Old Nov 28, 2012 | 05:33 PM
crazzywolfie's Avatar
crazzywolfie
i would check the rear brakes. if there is some abnormal wear on the pads then that is most likely were your problem is.
Old Nov 28, 2012 | 05:54 PM
SEAL's Avatar
SEAL
Air can compress and cause a pulsation in the caliper piston that can show up as a vibration.
Old Dec 4, 2012 | 02:23 PM
tarheelboy's Avatar
tarheelboy
SEAL, Thanks for your help. I bled the front left brake again and you were right. There was air in the caliper. The vibration is still there but not as severe. I am going to bleed the other wheels this weekend as well as check the rear brakes(crazzywolfie) Thanks to you too.
Old Dec 11, 2012 | 08:30 AM
Scooter78's Avatar
Scooter78
Did that solve your problem?
Old Dec 12, 2012 | 10:23 AM
tarheelboy's Avatar
tarheelboy
not completely. the back brakes were bad and the drums were warped. i changed all that out. now i need to change the wheel cylinder (slave cylinder). only one shoe is moving. maybe that will do it.
