Need help with parts please!
Old Dec 7, 2012 | 05:48 PM
crazzywolfie's Avatar
crazzywolfie
as far as i know they did not start using the magnum 360 until 93. i think 89 was the first year the la 360 were TBI
Old Dec 9, 2012 | 04:45 PM
xjarhead69's Avatar
xjarhead69
Originally Posted by SEAL
You can believe your Haynes manual if you want but I would point out that it wouldn't be the first mistake ever found in a Haynes manual. I happen to actually have an 89 with a non-Magnum 318 with a harmonic balancer in my garage. I believe the 318 magnums started in 90 or 92 and the 360 Magnums were an option as early as 89. I know they stopped making the 318 LA in 91. As always I am willing to learn.
Here is some goods reading on the subject http://www.allpar.com/mopar/318.html.
Dave
Old Dec 9, 2012 | 05:17 PM
sls001's Avatar
sls001
That's not what my Haynes says....1989-93 5.2L V8, EFI. And IIRC, that is the Magnum.
You can not take what a Haynes manual says as anything more than a guide since in this case it is incorrect. Simply having fuel injection didn't make them the magnum engine design.
1992 was the first rear for the 5.2 (318) magnum and 1993 for the 5.9 (360) magnum.
Old Dec 9, 2012 | 05:20 PM
sls001's Avatar
sls001
Well, I don't know how the vins are setup in the Netherlands but here in the US, Vin code Y is the 5.2L Magnum V8, aka the Dodge 318 Magnum.
The 318 is internally balanced where as the 360 is externally balanced, so on the 360, look for the harmonic balancer on the crank.
It doesn't matter if the engine is internally or externally balanced it will still have a harmonic balancer\vibration dampener on it.
Old Dec 10, 2012 | 05:45 AM
SEAL's Avatar
SEAL
Here is the pertinent Quote from the ALLPAR article you posted. It is all the way at the bottom of the article.
"Chronology of the LA series Chrysler V8 engines
(Thanks to Stephen Havens)
1992 - Magnum appears on 3.9 and 318 (5.2)
1993 - Magnum 360 (5.9) appears"
Old Dec 10, 2012 | 10:09 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Well, I done learned something today.
Old Dec 10, 2012 | 02:04 PM
SEAL's Avatar
SEAL
I figure learning and teaching is what this forum is all about, and that is the reason we are all here. JMHO
Old Dec 10, 2012 | 03:24 PM
dodge dude94
Very true.
Either way, the OP needs to drop his Vin on us...lol
Old Dec 10, 2012 | 03:38 PM
crazzywolfie
we don't need the vin. if you check summit headers that fit a 318 will also fit a 360, 340 or 273
http://www.summitracing.com/search/y...rtment/exhaust
Old Dec 12, 2012 | 03:58 PM
ReLXe's Avatar
ReLXe
Thanks guys. I've checked summit racing and found the header(s) i need.
130 bucks for 2 headers + all gaskets and misc. wow.... now thats cheap
Only the shipment costs are 250! bucks....
Oh well, guess that'll have to do Thanks again!
