Smog or no smog?
Old Dec 11, 2012 | 08:24 AM
Scooter78's Avatar
Scooter78
Originally Posted by firefish
One of my many faults is that I have major difficulties when it comes to leaving stuff alone...
You are in good company here, then.
My vote will always go towards de-smogging an engine. As long as it wont get you in trouble with the law, I would go for it.
Old Dec 15, 2012 | 02:35 AM
firefish's Avatar
firefish
Some progress...
I've ordered a rebuilt and custom ThermoQuad that bolts on to the stock Quadrajet intake. I'll also swap the distributor, either for a remanufactured early 70's 340 unit or a Mopar Performance. Together with headers it'll be a nice little upgrade.
And about headers, the only ones available locally are Flowmaster. I stayed away from them when I had a 'cuda because of supposedly poor fit but I figure that there's more room in a truck and hence they should be ok. What do you say?
Old Dec 15, 2012 | 05:35 AM
SEAL's Avatar
SEAL
You should have a pick-up coil type distributor and early 70 340s didn't as far as I know. Are you planning on replacing the entire engine ignition system?
Old Dec 15, 2012 | 05:44 AM
firefish's Avatar
firefish
A distributor from -72 and should be a direct swap because, IIRC, that was the year Mopar ignition went electronic. But I'm leaning towards a kit from Mancini complete with box, wires and coil.
Old Dec 16, 2012 | 10:51 AM
Scooter78's Avatar
Scooter78
If it were mine, I would look into the Chevy HEI style dizzy. You get to throw most of the Dodge ignition stuff in the trash and get more volts to the plugs.
