Slight vibration
Old Dec 6, 2012 | 10:40 PM
Bshaw0331's Avatar
Bshaw0331
Default Slight vibration
Here is the issue i am having, between 40 and 45 mph my truck has a slight front end shaked whether it be accelerating, cruising or decelerating. It is a 1988 d150 with the 360 auto. It does have a small trans fluid leak i am trying to track down. Just curious if anybody has an idea of where the shake might be coming from or the leak might be coming from.
Thanks
Old Dec 6, 2012 | 11:18 PM
ghonhee's Avatar
ghonhee
Bshaw,
Can you describe the vibration a little bit more? Can you hear or feel it? Is the vibration there in neutral as well? You can also run the truck on jackstands and check for vibration there.
It could be your wheel bearings. I would also check out your steering system. Look for play in the tie rod ends and control arms. Also may be in tire balance.
Good luck.
Old Dec 9, 2012 | 01:34 AM
Bshaw0331's Avatar
Bshaw0331
It is a vibration/ wobble i can feel. I can't hear it. I would originally suspect tires and loose parts but it isn't a gradual vibe/ wobble up until 4o it doesn't even start until i get to 4o and stops between 45 and 5o. Also no vibration in neutral. It seems like it is starting right before it shifts to 3rd and stops as soon as it shifts into 3rd. So if there is anything else you wanna know i will gladly give more info. I'm new to the dodge world but learning.
Old Dec 9, 2012 | 07:31 AM
SEAL's Avatar
SEAL
I would check the tires and have them balanced. You may have thrown a weight. Are you feeling it in the steering wheel or thru the body?
Old Dec 9, 2012 | 09:33 PM
Scooter78's Avatar
Scooter78
Does it seem to get worse while coasting? If it gets worse while coasting, I would say a u-joint is suspect. Otherwise, I would definatly be looking at tires. I have one that is a little out of round. It only shakes between 40 and 48 mph. Other than that it is smooth as silk. (As smooth as a first gen gets anyway.)
Old Dec 14, 2012 | 10:14 PM
FlatBlackRam_01's Avatar
FlatBlackRam_01
+1 I see this a few times a day
Old Dec 16, 2012 | 01:23 PM
Comrade General's Avatar
Comrade General
Sounds just like the same issue Im having. I would guess mine is balance, hopefully anyway. And I can feel it through the steering wheel
Old Dec 17, 2012 | 02:01 AM
ghonhee's Avatar
ghonhee
Yep. After having the balance checked, the steering wheel vibration is usually indicative of wheel bearings or tie rod ends. But wheel bearings usually have quite a bit of noise with them.
Old Dec 17, 2012 | 09:27 PM
Comrade General
I sure hope not. Guy checked the bearing and one side was good but the other side was bad so those were replaced along with the hub. Packed all the bearings too.
Its not noisy though so thats good.
