My Speedo doesn't work....1991 W150
Old Jan 25, 2013 | 02:32 PM
Sniper X's Avatar
Sniper X
Default My Speedo doesn't work....1991 W150
So, when i bought the truck, the guy said he had troubleshot the problem with the speedo/odo/trip meter not functioning to a speedo drive gear. I have not looked but it seems logical. Anyway, I want to know where that gear is and how to check it in my truck...particulars below in my sig line.
Old Jan 25, 2013 | 02:52 PM
crazzywolfie's Avatar
crazzywolfie
it should be near the output shaft of the transfer case. there should be a sensor that screws on or something. before you check the gear you may want to mark the housing because it rotates. if it is not just right i think the gears may not engage or could possibly strip. they are only plastic.
Old Jan 25, 2013 | 05:29 PM
Sniper X's Avatar
Sniper X
Well, THAT was easy! I got under the truck about five minutes after I posted this, there was an obvious speed sensor there on the tail of the T case, I removed it with a big set of channel locks, tried to run the shaft connected to the gear inside the housing and it was gronchy as hell. I looked on the net for a speed sensor and found it. It turns out NAPA had them in stock since it is the same for a bunch of cars and trucks so I went and bought one. Cast 50 bucks but it took three minutes to swap out and the thing works perfectly! It is almost exactly accurate too only being almost a MPH slower than actual which I checked with my GPS. Here's what it looks like and where it is.
