rectangular headlight measurement on my 1991
Old Mar 4, 2013 | 06:26 PM
Sniper X's Avatar
Sniper X
Default rectangular headlight measurement on my 1991
Truck it at home, I am not so need someone to measure it unless they know! I am ordering some Cibies and need to know if it is 7.9 x 5.5 inches, or 6.5 in wide by 4in.
thanks!
Old Mar 4, 2013 | 06:41 PM
crazzywolfie's Avatar
crazzywolfie
i think the ones you are looking for are called 200mm lights.
Old Mar 4, 2013 | 06:43 PM
Sniper X's Avatar
Sniper X
200mm x 142mm would be the 7.9in x 5.5in then, which is great since Cibie still makes their super fine housing for that size. I can stick in a H4 lamp that is 80w on low beam and 130 on high......
Old Mar 4, 2013 | 06:57 PM
crazzywolfie
i don't know if you would need 80w or 130w in housings that nice. i was possibly thinking about ordering some hella housing. i have been meaning to ask sls001 how he likes the ones he ordered.
http://www.rallylights.com/detail.aspx?ID=744
Old Mar 5, 2013 | 06:42 AM
sls001's Avatar
sls001
I picked up the Hella 200mm Rectangular E Code Conversion Headlight Kit with Hella 60/55W Xenon +50% H4 Bulbs.
In combination with the relays they are fantastic. I might have been able to get away with the brighter H4 bulbs but at the height my truck sits they would blind anyone I was behind.
I did also pick up a set of 130/100W Narva's from Daniel Stern Lighting for off-road use but haven't given them a try yet.
Old Mar 5, 2013 | 10:44 AM
Sniper X's Avatar
Sniper X
I am getting the Cibies lamps and everything from Daniel Stern lighting. Fairly expensive for an old truck but other than a crappy paint job, my truck is real clean and has fairly low mileage. And I am a stickler about lighting! The whole thing including what I did on the relay install is going to end up at about 200.00 for the complete upgrade.
