Steering knuckle and hub/bearign assembly
Old Mar 9, 2013 | 09:53 PM
BobConley's Avatar
BobConley
Default Steering knuckle and hub/bearign assembly
Hi guys,
I'm pretty ignorant (uneducated) when it comes to most suspension work. I have a 2003 ram with a bad hub/bearing assembly. I've already ripped things right down to the hub and decided rather than fight with separating it from the knuckle that it would be easier to buy a new knuckle and swap it out.
What I'm trying to figure out is what do I need to get the knuckle off the truck. It's on the passenger side and I see the upper and lower control arms are attached and the pitman arm. What I'm curious about is do I need to buy new ball joints for the knuckle or are those actually pressed into the control arms? And what is the best or easiest way to get the control arms and pitman arm off the knuckle to remove it? This is a 2003 Dodge Ram 4wd with abs.
thanks for any info
Old Mar 10, 2013 | 11:05 AM
wontacceptthis's Avatar
wontacceptthis
You should try posting in the 3rd gen ram for your truck. This section of the forum is for 1993 and older trucks. I have no idea how to do that on a 2003. I could help you if it was ten years older though.
Old Mar 11, 2013 | 07:54 AM
BobConley's Avatar
BobConley
I was in the third gen forum and have no idea how this got posted here, I also tried to find a way to delete the post but never found it.
