never ruin this part
Old Apr 3, 2013 | 11:23 AM
Katzen's Avatar
Katzen
Default never ruin this part
so for a while i've been needing a replacement for my fuel level sender and was able to buy it before for a decent price now if you search the internet you will not find one that isnt a 200$ nos.....
if anyone knows where i can acquire one for a good price let me know please
Old Apr 3, 2013 | 11:49 AM
crazzywolfie's Avatar
crazzywolfie
we need more info like year the truck is. have you check the junkyards? most junkyardes usually punture or cut the tank to get the gas out so i doubt they would care if you cut the sending unit out and since i doubt they would give you much of a warrenty on a cheap rusty looking thing that comes out of the gas tank. only thing is you may have to kind of rebuild it. did you physically break yours or does your gas gauge just not work?
Old Apr 3, 2013 | 11:58 AM
Katzen's Avatar
Katzen
opps, its an 83 5.2, but its nasty and the level doesnt work, i know the gauge works when i was screwing with the level it moved but would drop to 0 when moved any further
Old Apr 3, 2013 | 01:20 PM
crazzywolfie
just because it looks nasty doesn't mean it don't work. with old trucks one of the biggest problems is bad connection. i know i have had my gas gauge quit working. just had reach for the wire on the sending unit and give it a small twist and gauge would start working again. if you have the sending unit out you can test it with a multi meter. i think with a empty tank you should have about 90 ohms resistance and when you have a full tank you should about 0 ohms resistance between the 2 terminals on the sending unit.
Old Apr 3, 2013 | 02:46 PM
Sniper X's Avatar
Sniper X
Mine is whacky too. BUT it does this....when FULL it reads EMPTY< but after about 20~30 miles of driving, it starts to read what MAY be accurate....till it gets down to about half a tank then it goes back and forth a little.
Old Apr 4, 2013 | 12:19 AM
Comrade General's Avatar
Comrade General
Mine has just started to not be accurate. Going down to E when Im really at half a tank
