transmission problem
Old May 7, 2013 | 02:33 PM
crazzywolfie's Avatar
crazzywolfie
A 32rh is the same as a a999
Old May 9, 2013 | 12:41 AM
LA6-250's Avatar
LA6-250
will the torque-flight 8 bolt on to the 3.9? im not sure, but wouldnt anything from 72-93 be usable? if i got an O/D trans, would i have to install something to actuate it manually (i.e and O/D button)?
Old May 9, 2013 | 05:00 PM
xjarhead69's Avatar
xjarhead69
This is what you need to know to go from 3 to 4 speed
http://www.transmissioncenter.net/SwapInformation.htm
Dave
Old May 9, 2013 | 05:22 PM
crazzywolfie
any 2wd small block v8 transmission should bolt up to the v6. the v6 is pretty much the same as the 318 except someone cut 2 cylinders off. now if you use a transmission out of a 92 or older vehicle you will most likely need to notch the bell housing to make room for the crank position sensor. also if you are doing the swap yourself you may want to make sure you remove the crank position sensor before you do the swap and keep it somewhere safe. a good crank position sensor is usually expensive and they usually get broken when people do engine or transmission swaps and don't remove them.
Old May 9, 2013 | 09:20 PM
LA6-250's Avatar
LA6-250
last questions. is there an aesthetic difference between the 30rh and 32rh? and I have a 32RH could i install a 32RE? or would there be major changes needed.
Old May 9, 2013 | 10:11 PM
xjarhead69's Avatar
xjarhead69
No you can not.
RH refers to a hydraulic governor and RE refers to electronic governor that is controlled by the computer.
Dave
Old May 9, 2013 | 10:20 PM
crazzywolfie
the 30rh is weaker than a 32rh.
Old May 9, 2013 | 11:54 PM
LA6-250's Avatar
LA6-250
I know that it is weaker ... but how would i tell if i was looking at a 30rh, as opposed to my 32rh?
