1988 ram van
Old May 15, 2013 | 03:15 PM
GerGerdes's Avatar
GerGerdes
Default 1988 ram van
no idea!
hi there, got an 1988 ram 250 van but wipers wont work.
i replaced the motor and the relay under the steering wheel, but no result.
what else could be a problem??
thanks&regards
Old May 15, 2013 | 05:07 PM
crazzywolfie's Avatar
crazzywolfie
have you checked for power at the wiper fuse?
Old May 15, 2013 | 11:52 PM
GerGerdes's Avatar
GerGerdes
did it, shows me the right current.
Old May 16, 2013 | 08:16 AM
crazzywolfie
have you checked for power at the wiper motor plug with the wipers on? could have a bad ground connection at the motor if you have power at the plug.
Old May 16, 2013 | 03:03 PM
GerGerdes's Avatar
GerGerdes
you were right...
what ive tried: direct connection from battery (minus plug) to wipermotorbody- it runs but rotates without running back like in an interval mode. must have a bad groundconnection. where is the correct connection from groundwire to battery, can i link it easily with the battery-minus-pole?
thanks so much
Old May 16, 2013 | 05:13 PM
crazzywolfie
The bolts that hold it to the body ground it.
Old May 16, 2013 | 10:28 PM
GerGerdes's Avatar
GerGerdes
as soon as the wire touch the motorbody,it get a bypass with sparks between wire and body and the fuse blow.
Old May 17, 2013 | 06:50 AM
crazzywolfie
if the fuse blows that usually means something is wrong. i would still take one of the bolts out of the motor mounts and clean it up with some sand paper or a wire brush and them put the bolt back in. fix the ground connection and then move on from there.
Old May 17, 2013 | 03:14 PM
GerGerdes's Avatar
GerGerdes
motor is built in, and the wipers are working like they should do. but one strange noise i can hear, at every rotate of the motorarm it makes a cracky noise. not this one like the relay do. it is in the motorbody and knocks every rotating round.
Old May 17, 2013 | 03:50 PM
Sniper X's Avatar
Sniper X
Then the bushings in the motor are worn out. You can't fix the bushings. I would get a new or better condition used motor and replace it. I really need to do my switch for my wipers because when I turn it to HIGH it blows the fuse.
