another brake problem
Old May 26, 2013 | 10:45 AM
JimT's Avatar
JimT
Default another brake problem
Hi all
I have a 1995 dakota 3.9 - 5 speed - 2wd..
the front calipers are the originals and started hanging up so I bought new
calipers (a lot cheaper then I thought).....
got the right one off and the new one on no problems...
got the left one off... and started putting on the new one....
somehow I got one of the mounting bolts slighly cross threaded.... so I didnt force it and got out my trusty tap and die set out..
well I had nothing that matched the size and threads of the mounting bolt...
so I went to 6 different places looking for a tap to clean up the threads.....
no luck... it looks like its a 3/8" x 20, I matched up the threads with a thread
guage so I know its 20 threads per inch...
I thought it might be metric, nope an 8 is to small a 10 is to large, couldnt find a 9mm to test it on
the only 20 I know of is a 1/4" x 2 bolt size....
is this a dealer only type thing???
anyone know where I might be able to get a tap or thread chaser for this
wiierd size???
thanks
Jim
Old May 26, 2013 | 10:35 PM
wontacceptthis's Avatar
wontacceptthis
You should try the 1st gen Dakota forum. My truck doesn't even have caliper mounting bolts.
Old May 26, 2013 | 11:09 PM
crazzywolfie's Avatar
crazzywolfie
can you possibly put the bolt in the hole from the other side and fix the threads?
