Can Anyone Help?
Old Jun 5, 2013 | 04:35 PM
popesgarage's Avatar
popesgarage
Default Can Anyone Help?
Imp new to this forum, but im hoping someone can help me figure this out. I fell in love with my 88 Ram, 318, four speed, ten inches of lift. Ive owned it for over a year and a half now and since i aquired it ive poured my soul into this truck, recently its been giving me problems. Rums beautifully at an idle, smooth and even, but when i put my foot on the gas, and raise the rpms it coughs and sputters, and wont run nicely until it gets above 2500-3000 rpms. I know the truck wasnt treated nicely by the previous owners because it was a pro mud rig, i would really appreciate any ideas.
Old Jun 5, 2013 | 04:41 PM
wontacceptthis's Avatar
wontacceptthis
If it was a pro mud rig, is it still TBI?
Old Jun 5, 2013 | 07:56 PM
popesgarage
Yeah sorry, it still has tbi, i replaced the tps hinking that that would fix it, but it still has the same issue.
Old Jun 5, 2013 | 08:36 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Honestly sounds like it's trying to run slightly lean to me.
Old Jun 6, 2013 | 09:46 AM
popesgarage
So if it is running lean, what would be the way to correct that, i know how to adjust the carb, but its computer controlled mix on the tbi isnt it?
Old Jun 6, 2013 | 12:13 PM
dodge dude94
You might have a jet clogged up.
Old Jun 6, 2013 | 02:51 PM
crazzywolfie's Avatar
crazzywolfie
you mean injector right?
while the truck is running you can look down the throttle body with a flash light. you should hopefully see a cone spraying from the injector.
Old Jun 6, 2013 | 03:01 PM
dodge dude94
^My bad, thought they were still called jets on TBI.
What he said.
Old Jun 6, 2013 | 05:36 PM
popesgarage
Thats a good idea, ill give it a try, Thanks for the idea.
Old Jun 7, 2013 | 01:12 PM
popesgarage
Ok, It doesn't look like that's the problem, both injectors are spraying nicely, even when I open the butterfly valves by hand. I also noticed, it only tends to have a serious problem under load between idle and 2500 or 3000 rpms, that's when its the worst, it doesn't act like it wants to die out, but it misses and runs choppy.
