5.9 Cummins/Allison 6spd swap into 1985 D350
Also, for controlling the tranny, you can get a aftermarket standalone TCU (transmission control unit, AKA transmission controller) for the Allison, then you can program all the shift points WITHOUT needing any thing else, only in most cases a TPS (throttle position sensor, on the P pumped cummins you might be able to use a APPS (accelerator pedal position sensor)).
Here's what you need
http://www.4btswaps.com/forum/showth...p-guide-thread
