4wd Stick
Old Sep 27, 2005 | 09:27 AM
Dodge4Life's Avatar
Dodge4Life
Default 4wd Stick
I have a 1982 ram, 4speed, 4x4, and I am having trouble with the shifter for my 4wd. When i am driving it will try to shift into 4wd and i cant get it to stop doing that. I have already tightened the linkages, but it still slips, should i change the whole thing out?
Old Sep 28, 2005 | 02:16 PM
vestpuzzle1's Avatar
vestpuzzle1
Default RE: 4wd Stick
Hey there,
If u take it out, go through it and put it back in. Sounds like the linkage is slipping.
I believe it is just like a clutch. Out of adjustment? LMK....R.V.
Old Sep 28, 2005 | 04:05 PM
whitey's Avatar
whitey
i've heard of transmission slipping out of gear because of a bad syncro. the same thing might be able to happen to your t-case except it can only go from 2wd to 4wd. or like mentioned before it just might need adjusting, if its adjustable.
Old Oct 1, 2005 | 05:48 AM
Chump's Avatar
Chump
Have you tried draining the transfer case and refill? If you drain the case, check the oil for metal shavings.
