Horn/radio problems
Old Jul 18, 2013 | 09:46 PM
85d250's Avatar
85d250
Default Horn/radio problems
Horn and radio just stopped working. The fuses are good anyone have any ideas?
Old Jul 18, 2013 | 09:57 PM
crazzywolfie's Avatar
crazzywolfie
do all you lights still work?
Old Jul 18, 2013 | 10:02 PM
85d250's Avatar
85d250
I pull the inside light fuse to use for my turning light. Does the inside light fuse run the horn and radio too?
Old Jul 18, 2013 | 10:07 PM
crazzywolfie
no but i think they should be powered by the same fusible link. if your headlights and all the exterior/dash lights don't work then you might have a blown fusible link.
Old Jul 18, 2013 | 10:29 PM
85d250's Avatar
85d250
Ok I know my headlights not working yet I have to replace the switch but the radio and horn worked before I pulled the fuse
Old Jul 18, 2013 | 10:34 PM
crazzywolfie
what about all the other lights? you could try testing to see if there is power at the horn/radio fuse. if there no power then it is most likely a bad fusible link. they eventually go over time.
Old Jul 18, 2013 | 10:48 PM
85d250's Avatar
85d250
It was the fuse I pulled out so it works now
