hood help
Old Jul 30, 2013 | 05:56 PM
LA6-250's Avatar
LA6-250
Default hood help
I'm wanting to swap my 1993 hood to the bird bath hood from 1974-1980.
I searched for other threads, but the one I found had had the pictures removed. so, my question is; will it fit? do I really need the cowl? I know about the latch, and not concerned about it. so any help and or photos would be great.
Old Jul 31, 2013 | 05:58 AM
sls001's Avatar
sls001
Yes you need the cowl and the wiper pivots and the hinges from the bird bath hood since the hoods were actually a different length. The latch as you know isn't exactly a "bolt-in" it requires some fabrication.
Here is some info with a couple pictures of the hoods on the 91-93 style grills
http://ramchargercentral.com/technic...55/#msg1132555
http://ramchargercentral.com/vehicle...53/#msg1838153
http://www.dieseltruckresource.com/d...d-t248783.html
http://www.dieseltruckresource.com/d...t268789p3.html
Old Aug 1, 2013 | 09:07 PM
LA6-250's Avatar
LA6-250
if I also swapped the grille then there wouldn't be any problems?
Old Aug 2, 2013 | 06:45 AM
sls001's Avatar
sls001
you would also have to swap the radiator support in order to install the older style grill
