Dana 60 or 44??
Old Oct 2, 2013 | 12:34 AM
NiNjAassasin545's Avatar
NiNjAassasin545
Question Dana 60 or 44??
Hey guys. Iv been trying to figure out for the past few days if i have a dana 60 or a dana 44 front axle.. i need to know because i want to buy a rough country lift kit and they make different lifts depending on the axle. I have a 1975 w100...
Thanks in advance!
Old Oct 2, 2013 | 08:19 AM
sls001's Avatar
sls001
If it is stock a W100 would only have a D44 but you should check anyhow to see if it has been swapped in the past
5-lug nuts D44, 8 lug nuts it could be a D44 or D60
If it has ball joints it is a D44 if it has King pins it is a D60
You could also post a picture
Old Oct 2, 2013 | 09:40 AM
Rkymtnh's Avatar
Rkymtnh
When did you get the truck ? If you've had it for years, then it's probably still the factory 44.
But not all 60's are KP's.
Old Oct 2, 2013 | 01:01 PM
Sniper X's Avatar
Sniper X
yep, unless it has been swapped, it is a 44.
Old Oct 2, 2013 | 08:10 PM
moe7404's Avatar
moe7404
"Resistance isn't futile, it is voltage divided by current." is that current info?
