4x4 quit working
Old Dec 26, 2013 | 11:23 AM
MNfarmboy's Avatar
MNfarmboy
Default 4x4 quit working
Christmas Eve, me and my friend were driving around in the new snow we had gotten. I was in 2wd and got stuck in a snowbank, i put in 4wd to get out, but I got nothing. The front wheels didnt turn, the front drive shaft turned so the tcase is working as it should. Driving home i put it in 4wd and i could slide all over the road, so i know the front wheels aren't being powered. Today I took the vacuum lines off at the actuator, and I do have vacuum, and it does switch line to line when it is shifted from 2 to 4. However, it is not a strong vacuum, it is definitely noticeable, but it is not very powerful. When it is in 2wd and the front end is jacked up, if you spin 1 wheel the other doesn't spin, when in 4wd and you spin 1 wheel, the other wheel still doesn't spin. It appears that either the vacuum motor or cad isn't working, how do I determine which is the problem?
Old Dec 26, 2013 | 10:16 PM
sls001's Avatar
sls001
It is very possible that the CAD actuator on the front axle failed.
Here is all the info you need on CAD:
http://ramchargercentral.com/vehicle...ks-to-the-faq/
Old Dec 27, 2013 | 11:02 PM
Comrade General's Avatar
Comrade General
Gotta be the cad, unless both hubs failed which I doubt
Old Dec 27, 2013 | 11:36 PM
MNfarmboy's Avatar
MNfarmboy
I have been out of town for a couple days and today I got a chance to dig into it, as it turns out it was the actuator, the shaft coming out of the vacuum motor was bent, and it was binding up. It must not have been working properly for a while because the 4wd light stopped working a couple months ago and I just assumed that the bulb burnt out. But with the new actuator the light started working again. Now I'm curious to know how the shaft would have possibly got bent, any ideas?
