1984 dodge shortbed
Old Jan 3, 2014 | 11:18 AM
Cmckinney99's Avatar
Cmckinney99
Default 1984 dodge shortbed
I have a dodge that i dont like the wheels that are on it can i get the wheels off of a newer truck to put on it its a 1/2 ton
Old Jan 3, 2014 | 02:58 PM
dozer556's Avatar
dozer556
If it's an '84, the wheels should have a 5 x 4.5" bolt pattern. Wheels from an '85 to '93 will not fit, since they have the larger 5 x 5.5" pattern. I'm not sure about '94 and up Rams.
I think you're going to be limited to pre-'85 stock wheels and anything aftermarket with the correct bolt pattern, backspacing and offset.
Old Jan 3, 2014 | 10:29 PM
318power83's Avatar
318power83
if your a 4wd or have heavier 2wd you should have the big bolt pattern, the big bolt 5 on 5.5, 94-01 wheels will bolt up, ive seen 3 or 4 with the newer chome wheels, the small bolt pattern 5 on 4.5 was offered for all 1st gen rams for lighter 2wds, if you have this pattern the newer wheels wont bolt up
Old Jan 4, 2014 | 02:32 AM
dozer556's Avatar
dozer556
I didn't mention this, as I assumed the truck in question was a 2WD. But you are correct, the W-series would have the bigger bolt pattern.
My bad.
Old Jan 5, 2014 | 01:25 PM
Comrade General's Avatar
Comrade General
5x5.5 is a pretty common bolt pattern so finding new or used wheels will be easy
Old Jan 21, 2014 | 10:00 PM
Cmckinney99
Sorry guys i had the year wrong its an 85 and thanks
