W150 with stock 3inch block
Old Feb 4, 2014 | 09:13 AM
weberw150's Avatar
weberw150
Default W150 with stock 3inch block
i was wondering if my truck has the factory 3 inch block dose it already have lift springs in the front , like if i bought a 4 inch lift springs would it give me four inches of lift or one.
Old Feb 4, 2014 | 10:19 AM
jcb11realtree's Avatar
jcb11realtree
i have a 91 w150 with leafs all the way around and mine has 3in factory blocks
Old Feb 4, 2014 | 12:41 PM
grantshultz1994's Avatar
grantshultz1994
if you buy a 4 inch lift it compensates for that block you can get ones from rough country that come with a new block or ones with new springs all the way around
Old Feb 4, 2014 | 04:34 PM
weberw150's Avatar
weberw150
ok thanks, i just wanted to check that since it came with a 3 inch block that it didn't come with 3 inch lift springs before i spend the money on a lift
Old Feb 5, 2014 | 11:19 PM
wontacceptthis's Avatar
wontacceptthis
I am under the impression that the 3 inch block was standard on all w-series 4x4 trucks, so that they could use the same springs on the w-series and the 2wd d-series.
Old Feb 6, 2014 | 03:54 PM
grantshultz1994
they should be yes
Old Feb 6, 2014 | 05:37 PM
sls001's Avatar
sls001
only on the 1/2 tons and some light duty 3/4 tons. HD 3/4 tons and 1-tons had a 6" block.
Old Feb 7, 2014 | 08:54 PM
wontacceptthis
I forgot about that little bit of strangeness. I recall seeing some discussion on a diesel forum about 6" block + double factory torque = wrappity wrappity wrap. Especially in reverse, I think.
Old Feb 16, 2014 | 07:36 AM
Scooter78's Avatar
Scooter78
6" block? Wow. When the sun comes up, Ill have to go look under my ton truck. For a 1 Ton, I feel like it sits kinda low. I have been thinking about a 2" lift or so, but if its already a six inch block, I don't want to block it any higher. I would have to spend the coin on new springs.
Old Feb 17, 2014 | 09:41 AM
Comrade General's Avatar
Comrade General
the 3in block is stock in the back, and the front springs are stock there there isnt a lift. A lift is always in addition to whatever was stock.
The truck I swapped axles from (a w250) had a 6in block. its now on my w150. I beleive my w250 has one aswell, currently double stacked...bad I know.
