1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
ok so rule that out then... umm... yours got that spark control computer in the driver side fender? sometimes if they get excess moisture in there then they can go bad.... could be a vacuum advance problem on the distributor too
Mine does have the scc. I replaced it about 3 years ago. No vacuum advance on the distributor.
is it an aftermarket distributor? mines an original 87 distributor and ive got the scc AND vacuum advance.... if you think you have broken valve springs then pull the covers and check!... could be an intake gasket leak too take some starter fluid or carb cleaner and spray around the gasket and if it revs up on its own wll there ya go its leakin
My 86 w150 with a 318 will run good at idle, but when you give it gas it stumbles almost like it is missing. But if you ease on the gas it will run good. And under a load it will fall on it's face. Any ideas? Thanks
You say you rebuilt the carb? Did the truck run fine for X amount of time after you rebuilt it? Or has it not run correctly since the rebuild?
