dome light issue
dome light issue
k so my map light works but the dome doesn't...which switch controls it is it the little metal ones in the front of the door jam by the door mounts or is it the bigger plastic ones towards the bottom rear of the door jam by the latch?
im assuming they are ground controlled because it has full power to the red wire all the time but no ground. its not the bulb either because I replaced it thinkin it was bad... any help is appreciated
thanks
thanks
Dome Light
the dome light switch is the located on the hinge side of the door. The larger plastic buttons work the seat belts and retract them when the door opens.
Those buttons usually don't go bad and if neither door works the dome light then that's probably not the problem. Its a simple circuit and I would suspect a bad ground. All the switches including the light switch use the ground as the switched conductor and I would suspect the ground wire "feed" from those switches is bad. This diagram shows it as a white wire but may be a different color on yours. I think there is a plug under the dash near the E-brake with a white and pink wire running under the carpet for the rear dome light. I remember seeing that when I replaced the carpet in mine last month.
If that is the dome light wiring you should have a hot all the time on pink. And continuity to ground on white with the door open or dash switch on.
