heads
Old 07-05-2014, 12:41 PM
grantshultz1994's Avatar
grantshultz1994
grantshultz1994 is offline
Default heads
so... its been almost a month that my truck is outta commission, blown head gasket. its got warped heads. my question is this:
if I have a set of magnum 318 heads, will they fit on my LA 318?
also I have a 4bbl intake that I was thinkin bout putting on it yay or nay?
Old 07-05-2014, 03:31 PM
xjarhead69's Avatar
xjarhead69
xjarhead69 is offline
Old 07-08-2014, 10:41 PM
moe7404's Avatar
moe7404
moe7404 is offline
on chrysler small block to swap from a 2 bbl to a 4 bbl. most of the parts that go to the carb are different. most of the time the cable is longer, the trans linkage is different, and the cable bracket might be different what it is the pull pin of the 4 bbl carb is more forward and more to the drivers side. all swaps are not the same. just do your research. the main thing is that the carb is pulled all the way with out jamming at WOT.
Old 07-10-2014, 07:23 PM
onemore94dak's Avatar
onemore94dak
onemore94dak is offline
This guy will probably know. http://www.ramscyl.com/chrysler.htm
Old 07-13-2014, 02:36 PM
grantshultz1994
thanks guys
sorry it takes me so long to reply now im home for the summer and I only have internet at my moms and without a running vehicle its kinda hard to get back and forth
Quick Reply: heads
