Air injection heads
Air injection heads
I've got a set of these heads from an older built 360 I bought cheap (mainly for the LD340 intake). They have dual valve springs are nice and straight, and the valves and guides check out fine. I've read about tapping the air injection holes and using set screws to block them. That seems overly time consuming. Can't a guy just weld the holes shut? Then no problems with potential leaks ever.
