1992 ram 150 wont start??
Old Oct 24, 2014 | 01:28 PM
pintobro's Avatar
pintobro
Default 1992 ram 150 wont start??
This is my first post and i am having a serious issue that i cannot figure out. i was driving my truck on friday and i left the hyvee parking lot in town and it has a bit of a bump when you leave the lot. it was running fine before then, was backfiring a bit in the days leading up to this, but when i hit the bump the truck just died instantly. all the lights and radio ect, still work, but when i turn the key it doesnt make a noise. no clicks, cranks or anything. battery and altinator are fine, starter has power going to it, i checked for wires that may have come loose but could find none, i also checked all of the grounds that i could find and they all were fine. i dont think i checked all of them, i dont think it would be the starter since it was already running. but im completly lost here.could it be the ignition? or maybe a short? i dont have much cash to spend so i hope its something simple. any advise would be greatly appreciated. i gotta get this fixed as soon as i can its my only car at the moment, its a 1992 dodge ram d150 2wd single cab long bed 318 auto tranny and 82,000 miles. BTW it is a stripper model no ac or anything. here are some pics of it:
http://images.craigslist.org/00X0X_f...iD_600x450.jpg
http://images.craigslist.org/01414_a...Us_600x450.jpg
http://images.craigslist.org/00u0u_f...vd_600x450.jpg
http://images.craigslist.org/00A0A_e...J0_600x450.jpg
Old Oct 24, 2014 | 01:39 PM
pintobro's Avatar
pintobro
i was told by a friend that the engine might have siezed up? idk about that though
Old Oct 26, 2014 | 09:26 PM
KevenP's Avatar
KevenP
Will the engine crank over?
Old Oct 29, 2014 | 07:12 PM
grantshultz1994's Avatar
grantshultz1994
check the little relay box for the starter on the driver side fender
Old Nov 8, 2014 | 03:15 PM
scorchedwynd's Avatar
scorchedwynd
^ hes good it wouldnt seize for that, may have a bind in the flywheel and starter. take the starter off and see if the it will turn over. the backfiring is from timing being off or its sucking air.
Old Sep 5, 2023 | 04:07 PM
Yukiinadodge's Avatar
Yukiinadodge
Default 92 ram won’t start
Did you ever get it fixed having the same problem minus the backfire you had
Old Sep 6, 2023 | 10:41 AM
Moparite's Avatar
Moparite
Thread is from 2014 and the op hasn't been here since then. Start a new thread with your vehicle info and problem.
