no spark issue from a 1993 d350
Old Mar 24, 2015 | 06:25 AM
goldsmobile's Avatar
goldsmobile
Default no spark issue from a 1993 d350
Ok so i bought this heap...er truck this past weekend because of the motor. Its got a 360 magnum with low mileage and good compression on all cylinders. The problem is an electrical one now. It has no spark. The former owner had the ECU rebuilt, put a new crank position sensor and it appears a cam sensor in it. He says he only did the crank position but the cam sensor looks sorta new too. The relays on the drivers side inner fender are clicking when the motor is cranking but the coil is not sending out spark at all. From all my reading it seems the likely culprit is still the cam position sensor or a splice in the wiring somewhere that goes bad? Anyone else able to help out with this one? It had the former owner stumped and i would like to get this up and running and then into my truck lol.
forgot to add i pulled the codes and it is getting a code 11 which is timing chain/bad hall effect/cam sensor/crank sensor. Any or all of those. Oh and motor has somewhere south of 39k miles on it.
Old Mar 24, 2015 | 11:10 AM
xjarhead69's Avatar
xjarhead69
R u getting fuel?
Dave
Old Mar 24, 2015 | 04:24 PM
goldsmobile
Yes i forgot to mention that. Im getting fuel pressure at the rails.
Old Mar 24, 2015 | 06:45 PM
xjarhead69's Avatar
xjarhead69
Is it squirting fuel when you crank engine?
Dave
Old Mar 24, 2015 | 07:39 PM
goldsmobile
We held the shraider valve open with a screwdriver and cranked it and it did not squirt but after a few cranks you can push on it and it squirts fuel out under pressure.
Old Mar 25, 2015 | 12:12 PM
xjarhead69's Avatar
xjarhead69
Could be that its the ASD relay.
Dave
Old Mar 25, 2015 | 04:03 PM
goldsmobile
Isn't the ASD relay one of two that is mounted to the drivers side inner wheel house? I tried two different relays in there and it still would not start.
Old Mar 25, 2015 | 07:13 PM
xjarhead69's Avatar
xjarhead69
Do you have the factory service manual for this truck?
If so check to see if it has fusible links.
Dave
Old Apr 1, 2015 | 07:01 PM
goldsmobile
I have the Haynes now. I do in fact have fusible links on the inner fender. The haynes does not go over testing them however. Do i just stick the prob through the rubber lining on the wires and make contact that way? Or is there a better way to check for broken wires.
