Cummins into 1990 1/2 ton suburban
Old Jul 4, 2015 | 11:34 PM
Stone007's Avatar
Stone007
Default Cummins into 1990 1/2 ton suburban
Ok, so I swapped the 6.2L Chevy diesel in my 1990 suburban with a 12 valve Cummins, 5 speed getrag, front and rear axles all from a 1991 w250 donor truck. Swap went great! Everything was going very well until I had to renew the tags and get emissions. The emissions testing station said they couldn't test it because of the motor swap. So I went to the state inspection facility to get the proper inspection for testing. After an hour of waiting they came out and told me since the Cummins came out of an 8500 gvw pickup and my suburban is 7300gvw it's not legal anymore. They told me Cummins were never put into a truck under 7300 gvw. Has anyone run into this, maybe have some suggestions? I'm trying to find a way to register it out of Denver metro area, but running into proof of residence... Fearing it's in the "system" now I might be sol. Spent a lot of time on this project only to have bureaucratic BS tell me I can't get registered.
Any thoughts or ideas would be greatly appreciated.
Thanks
Old Jul 5, 2015 | 09:03 AM
Should have checked your local laws before the swap. Laws are laws. Hard to get around them unless you can find an inspection station that will "look the other way".
Old Jul 5, 2015 | 11:52 AM
HammerZ71's Avatar
HammerZ71
Yep, no way short of registering someplace without inspections. Was a thread on a dedicated Diesel forum a year or so back where a guy had a problem in CA. Blown 6.4 they dropped a 12V in. Had to pull it and go to a 24V and even after that it was a year at a specialty Fummins shop and like $18k later they still were working to make it pass CA inspection.
And they didn't have the GCVW hurdle you do...
Old Jul 10, 2015 | 08:10 PM
xjarhead69's Avatar
xjarhead69
Thanks
Maybe try retitling it with a "Rebuilder's Title" at 8500 gvw since you swapped axle also.
It's worth a shot.
Dave
