1992 D150 Start then Stalls help!
Old Jul 12, 2015 | 12:08 PM
Fishman2580's Avatar
Fishman2580
Angry 1992 D150 Start then Stalls help!
Ive got a 1992 D150, was driving down the road and truck just died. Went to restart and it fires then dies 2 seconds later. Got it home figuring it had to do with the fuel system. Put a gauge on it and when i cycle the key on, I have fuel pressure 40psi. I can also hear the pump run like normal for 2-3 seconds. i go to crank and once it fires the fuel pressure drops to 0psi and the truck stalls. Ive replaced the ASD relay and the Fuel pump relay. Not sure where to go from here.
only code the truck is showing are
32: EGR solenoid Circuit
51: O2 signal lean (Which i know is fine because it has an exhaust leak)
Any help would be greatly appreciated!
Thanks in advance!
Old Jul 12, 2015 | 06:07 PM
Moparite's Avatar
Moparite
Could be the fuel pump itself.
Old Aug 12, 2015 | 09:03 PM
MagnumD150's Avatar
MagnumD150
My 90 d150 did the same thing. After chasing this headache for 3 days I decided to change the computer.
In my truck the module was built into the computer. Bought one at O'Riley's for 260 something. And she's
Been running great ever since. Let me know if this helps you out. Good luck.
Old Aug 21, 2023 | 02:09 AM
Morphas1s's Avatar
Morphas1s
Default Heres my 92, had her for 8 years now. I am the second owner.
Old Mar 13, 2025 | 08:00 AM
SlowRango5.2's Avatar
SlowRango5.2
Thanks in advance!
Most likely the throttle position sensor if it's throttle body injected, my Durango has done that before and that's what the problem was
Old Mar 13, 2025 | 05:57 PM
Moparite's Avatar
Moparite
You may want to look at the date of the thread you are replying to! Yes it's 10 years old and Fishman2580 hasn't been here since then either.
