New member 318 rebuild
Old Nov 6, 2015 | 01:06 AM
chainsaw5024's Avatar
chainsaw5024
Default New member 318 rebuild
Hello gentlemen I'm a newbe here I have a 91 W150 I'm rebuilding
Block is junk will I be able to use a block out of a early 80's truck
And change intake . Or do I have to get a 88 to 91 block .Can
Anybody lead me in right direction thanks
Old Nov 6, 2015 | 09:19 AM
Moparite's Avatar
Moparite
Might consider upgrading to a magnum.
http://www.magnumswap.com/
http://www.magnumswap.com/using-la-parts-on-a-magnum/
Old Nov 6, 2015 | 12:20 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
I would upgrade also.
Old Nov 24, 2015 | 04:29 PM
L0krin's Avatar
L0krin
From: Home is Michigan, Currently living in Virginia.
I had an 89 W250 awhile back, and it had the throttlebody injection intake on it. The only difference between the older blocks and the 88-91 that I can think of was the newer blocks had roller lifters. I ended up getting a block out of a '79 Ram for my '85 but I wanted to stay with the carburator setup for price and simplicity. As far as I know you should be fine getting an older block and re-using your intake. However I agree with the guys above that said to just upgrade to a magnum.
