1987 2wd dodge lift kit help!!
Old Sep 28, 2019 | 12:00 AM
crazzywolfie's Avatar
crazzywolfie
stock shocks should be fine as long as you are still running stock lower control arms. sometimes kits come built for 4x4's which already have a spacer block between the axle and leaf spring so kits come with very long u bolts and might just need to be replaced or possibly cut to work with a 2wd which doesn't have a lift block from the factory.
Old Sep 28, 2019 | 08:36 PM
85ol’blue's Avatar
85ol’blue
Ah awesome, thanks! Yeah I’d essentially just be looking to get longer coils for up front and just the block kit for the rear.
Old Mar 29, 2023 | 08:17 PM
PapaGrizzly89's Avatar
PapaGrizzly89
The super lift blocks I could find said for 4wd only do they still fit the 2wd rear for the lift
Old Mar 29, 2023 | 08:20 PM
PapaGrizzly89
Default Hey man I just need to know so I can replicate
Originally Posted by LowNSloan86
i bought the super lift 2"block kit for the rear and had springs made for the front by Eaton Detroit.
going to be doing a 3" body lift soon
what were the spec for the springs from Eaton and when I went on super lifts for their block kits it said for 4wd only do they still work for a 2wd 86 d150
