1990 W150 Initial Brake Drag
Old Oct 9, 2016 | 07:29 PM
allparman's Avatar
allparman
Default 1990 W150 Initial Brake Drag
Hello All,
I have a '90 W150 that I bought recently and it has an interesting issue. Right at startup when I put it in drive the brakes seem to lock up and not allow me to move, I have to rev it up quite high before I get motion. Yet when I put it in reverse it moves freely. Once underway if I come to a stop and go again it does not seem to be a problem. I will be jacking it up and investigating shortly, I just wondered if anyone has had this happen to them as well?
Old Oct 12, 2016 | 07:05 PM
Moparite's Avatar
Moparite
Never had that issue with mine. But make sure the calipers are not stuck and you grease the sliders.
Old Oct 14, 2016 | 12:01 AM
allparman's Avatar
allparman
I jacked up each wheel individually, the right rear is the one grabbing. I took it for a couple mile test drive and that drum was very warm, almost burned my finger. I will be tearing it apart here shortly next week, hopefully it's just a bad wheel cylinder or stuck hardware.
