1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
i have a 1974 d200 w/ 318 engine and a simple carter 2bbl bbd carb. the large rear vacuum port has no vacuum at idle. is this normal and if so what is the best way to adjust mixture with a vacuum guage? if NOT normal, what is the fix on the carb.
Not sure about the large port . When adjusting mixture with vac gauge both screws should be approx the same number of turns out , Adjust to highest vac reading . may have to go back and forth a few times . I usually check ignition timing first before adjusting carb . Timing is a large factor in engine vacuum .
