1986 W-150 Ignition probs
Old Aug 28, 2017 | 12:21 PM
doc_bd's Avatar
doc_bd
Default 1986 W-150 Ignition probs
Hi there, I have a 1986 W-150 with 5.2/318. I had zero probs for 5 years, but after moving to NC, on my 1st day here, I left he truck on Acc. overnight...drained the battery.After charging the battery, it would not start. No spark to the plugs. So far I have replaced the ignition control module, the ballast resistor, the coil, and the pickup coil. I get no spark out of the coil. The wiring harness has been seriously hacked before I bought, but ran fine for 5 years since. I get voltage to the coil, but none out. Is there some hidden piece of electronics I could be missing ???
Old Sep 1, 2017 | 08:14 AM
Moparite's Avatar
Moparite
In 76 Chrysler started using the lean burn system. It was problematic and most removed it.
https://www.allpar.com/mopar/lean-burn.html
They probably installed a standard electronic ignition from a different year vehicle. Pics would help identify what you have. Here are the two most popular Chrysler systems...
Old Sep 7, 2017 | 05:30 PM
doc_bd's Avatar
doc_bd
I have the dual ballast system...modified, tho. I am also trying to find the wire coming out of the package from to coil to inside the truck. I have narrowed it down to tha fact that I get power to the coil, but no power out it.
Old Sep 7, 2017 | 06:51 PM
Check resistance across the coil. Should be zero to six ohms...... If it is open, replace the coil.
