abs brakes light on dash
i have a 1993 dodge d250 with a one ton front and rear end . i just replaced the brakes all the way around but when i start engine all warning lights will go off for a minute then the ABS and parking brake warning lights come on , i have bled the brakes and checked everything i can think off does anyone out there have any ideas on what to check. thanks
Same thing happened to me after I did a complete brake line replacement and brakes. I also replaced the ABS valve mounted to the frame at rear and the sensor on axle.
I did not replace the sensor on the rear diff.
The parking brake and ABS light still wont go off. Any solutions/advice out there?
I'm about ready to get into the dash and delete the warning lights.
