84 dodge power ram 4x4 3.55 rear
Old Nov 18, 2017 | 02:35 PM
Terry_f527's Avatar
Terry_f527
Default 84 dodge power ram 4x4 3.55 rear
I have a 1984 dodge power ram w150 custom the rear end is shut i was wondering what year dodges are the same so i can just swap it out
Old Nov 19, 2017 | 02:17 PM
u2slow's Avatar
u2slow
Could be a 8.25" or 9.25" axle. 3.21 and 3.55 are both common ratios. You want to look at 81-93 4x4s and 85-93 2wds to get the right wheel bolt pattern (5x5.5")
Old Nov 23, 2017 | 09:29 AM
Terry_f527's Avatar
Terry_f527
Default 84 dodge w150 power ram
Can you swap disck brake axles for drum brake axles ?
Old Nov 29, 2017 | 05:34 PM
u2slow's Avatar
u2slow
The '94+ ram diffs are ~5" wider. I know spring spacing is the same on a 2ndgen (94-02). I think the first disc brake rear axle is 2001.
Old Nov 29, 2017 | 06:06 PM
Terry_f527's Avatar
Terry_f527
Default 84
Do you know what years are the same ratio as 84 ?
Old Nov 29, 2017 | 06:16 PM
u2slow's Avatar
u2slow
There's usually at least two ratios available regardless of year. Here's the ratios I've had on other 1/2-tons...
- 84 ramcharger 2wd (auto) 3.21
- 88 D150 2.76 (auto)
- 90 ramcharger 4x4 (auto) 3.55
- 96 ram1500 4x4 (5spd) 3.55
Old Dec 28, 2017 | 06:49 PM
pentastar666's Avatar
pentastar666
Only way to tell is to actually check possible donor rears . No easier way . there are always options each year .
