If Your doing a Magnum Swap-
Old Nov 24, 2017 | 06:16 PM
rickpilgrim's Avatar
rickpilgrim
Default If Your doing a Magnum Swap-
here’s a Great site on LA to Magnum swaps-
http://www.magnumswap.com/
Old Jul 3, 2022 | 11:33 AM
Dk2jheath's Avatar
Dk2jheath
I will definitely look into that. Thank you for some direction!
Old Jul 3, 2022 | 11:50 AM
Dk2jheath's Avatar
Dk2jheath
Just realizing how obvious that site name is that maybe I should have tried that first 😂😂
Old Jul 3, 2022 | 01:36 PM
Dk2jheath's Avatar
Dk2jheath
Unfortunately that site is focused on swapping just the engine. My 46Rh trans blew up and broke the case. So we had a wrecked 2000 Ram 1500 so I am wanting to install engine and trans along with the entire electrical system. My biggest issue is that the 241d tcase won't fully engage due to spacing issues with the different OD housings with the Rh being longer and deeper due to the governor. I think I can make everything else work but this is a real brick wall
Old Jul 3, 2022 | 11:18 PM
Dk2jheath's Avatar
Dk2jheath
Well quick update. I got brave and tore down both tcase and switched the input shafts. Same gear just a shorter input collar and it bolts up. I'll have to have modified drive shafts made but it looks like it'll work. Be a while before I get it running but I'll add updates. Electronics is next on the list! ​​​​​
