towing capacity D350-85
Old Dec 4, 2017 | 03:03 PM
Robert A's Avatar
Robert A
Default towing capacity D350-85
Hello
I am looking for the towing capacity for my D 350 dually-85, runs on gas, with a 360 under the hood.
cant find the answer anywhere.
Thanx !
Robert
Old Dec 4, 2017 | 09:57 PM
Is there a sticker in the drivers door frame? Should tell ya the GCWR.
Old Dec 6, 2017 | 10:49 PM
u2slow's Avatar
u2slow
Tow ratings aren't on the door jamb. Dodge's are almost impossible to find. The Ford and GM ones I have seen are in dealer brochures, and fleet ordering catalogs.
The rating varies, with engine, trans, 2wd/4wd, axle ratio, and other optional equipment (coolers, HD suspension, etc). The tongue/pin weight goes toward the GVWR. Odds are you will run into licensing and insurance snags before you overload the truck. That's the case here anyway... 4600kg (11,000#) limit before you need an upgraded driver's license and annual inspections.
