1989 ram d150 318 throttle body
Old Dec 26, 2017 | 01:03 AM
Kenneth Gardner's Avatar
Kenneth Gardner
Default 1989 ram d150 318 throttle body
Hello I'm stumped on getting my truck to run right. I've replaced all the sensors on tbi. But it's kinda got a skip to it when u rev it up and are taking off down the road. But u can floor board it and it runs perfect. Any help?. I Kno someone has ran into this problem. Just put new water pump and timing chain on it. Plugs. Wires. Cap. Rotar button. Map sensor. Throttle position sensor. Fuel pressure regulator. Idle control motor. Fuel filter. Hell all that's left to change is fuel pump. Injectors. And coolant sensor.
Old Dec 26, 2017 | 02:15 AM
crazzywolfie's Avatar
crazzywolfie
could try replacing the hall effect sensor. if the engine is running i doubt the fuel pump is the issue since the engines require so little pressure to keep them running. have you tried pulling codes to see if the computer is seeing any issues?
