i'm trying to figure out the rearend ratio on a D150 2x4 8 1/2 inch differential
Old Dec 30, 2017 | 07:07 PM
1981 D150's Avatar
1981 D150
Default i'm trying to figure out the rearend ratio on a D150 2x4 8 1/2 inch differential
!981 D150 2x4 "Miser"
It has two tags on the differential one says "35" the other says "2610"
Old Dec 30, 2017 | 10:44 PM
crazzywolfie's Avatar
crazzywolfie
35 might be 3.55 gears but best way to tell is to either pull the over and change the fluid or hooking up a tach. if you got 3.21 gears the engine will run at about 2000rpm at 50mph or 2000rpm at 45mph with an automatic slush box. if the truck is a standard it most likely has 3.21 gears. stardard trucks are always geared like that.
Old Dec 31, 2017 | 01:24 AM
primem's Avatar
primem
-you could remove the pan cover and count the crown and pinion teeth
-you could raise the rear end, spin the tires 1 revolution and count the turns of the driveshaft
-dealer build sheet; call the parts dept and provide your vin. Call fca corporate and they can email you a build sheet.
-try the vin decoder in the tools section
Old Dec 31, 2017 | 12:19 PM
Moparite's Avatar
Moparite
If you are taking the cover off just look on the side of the ring gear, It should say what it is.
Old Jan 5, 2018 | 03:27 PM
u2slow's Avatar
u2slow
The '88 D150 I wrecked out had 2.76. Was a 318/auto longbed.
