1990 w150 no oil pressure
Old Feb 18, 2018 | 11:46 PM
Bullyfrog's Avatar
Bullyfrog
And are you losing oil?
Old Feb 18, 2018 | 11:49 PM
Mr.tillman99's Avatar
Mr.tillman99
It has always Had a slight tick from what sounds like a lifter but other than that it sounds fine it's got a fresh 5qts of oil and it's never had any leaks
Old Feb 18, 2018 | 11:50 PM
Mr.tillman99
I even pulled a rod cap and the bearings still look new but when I took the pan off the bottom had a metallic look to it but thats probably from no oil pressure
Old Feb 19, 2018 | 12:13 AM
Bullyfrog's Avatar
Bullyfrog
I would double check theck the pump manuly cranking it with the pickup tube in a pan of oil to make sure its actually pumping correctly
Old Feb 19, 2018 | 12:16 AM
Mr.tillman99
Will do I'll update you on it tomorrow
Old Feb 19, 2018 | 12:19 AM
Bullyfrog's Avatar
Bullyfrog
Old Feb 20, 2018 | 03:27 AM
Mr.tillman99
Well pulled the pan and put the pump in the pan and it pumps good i also double check to see if the shaft turns with the engine any ideas?
Old Feb 20, 2018 | 06:41 AM
Moparite's Avatar
Moparite
When it was rebuilt where all the oil gallery plugs removed? If so maybe one was left off and just letting the oil drain back into the pan. I think there are two in front of the block.
Old Feb 20, 2018 | 01:46 PM
Mr.tillman99
They were both put back in it's been 10k since last rebuilt and it's been good till just last week could they fall out?
Old Feb 21, 2018 | 07:46 AM
hichamaziz's Avatar
hichamaziz
have you checked with a mechanical gauge?
