1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
on an old 1986 D150 with slant 6 motor, the windshield wipers has 2 settings, low and high. It will no longer work on high, just low......should I replace motor or the switch or what, any ideas?
Not sure if this will work on Dodge but i had a gmc truck and wipers worked only on high. I took the circuit board out and solder it and started working.
