1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
no one sells any as far as i know. 1 side is round and the other is flattened to the tailgate can be installed and removed easily. fords have ones that just bolt on but i am not sure if they would work with a dodge or not. worst case scenario you could just weld some pipe to the box where it is needed. my dad did that on his ford instead of buying the proper replacement parts.
Here is a link with pictures of that setup when i installed mine.
https://dodgeforum.com/forum/4th-gen-ram-tech/206115-power-tailgate-lock-install.html
